Just picked up a w2207h at Best Buy today with revision # STM 002
Panel # is LTM2201M1-LO1
Seems like they are putting samsung panels in the 2207h now
Manufactures date: April 2008
HP w2007:
Code:REV. Panel Code Brand of Panel PTG001 PTGM25 ???? ATG001 ATGM24 ????
HP w2207:
Code:REV. Panel Code Brand of Panel STM001 LTM220M1-L01 Samsung GTM001 LM220WE1-TLB LG GTMV1.6 LM220WE1-TLB1 LG ITM001 MT220WW01-V1 Innolux ITM002 ???????????? Innolux?
HP w2207h:
Code:Rev. Panel Code Brand of Panel STM002 LTM220M1-L01 Samsung ATM002 LM220EW01-V2 Innolux GTM001 LM220WE1-TLB LG GTM002 LM220WE1-TLB LG
How to find your panel code:
1. Turn off your monitor.
2. Press and hold the 'menu' button.
3. Turn the monitor back on.
4. Release the menu button.
5. Press the menu button again.
6. A "Service..." option will appear.
7. Select it and it will display the Panel's model number at the bottom.
8. Post your findings here, if you'd like.
As far as the calibration goes: again, if you have an Nvidia based graphics card I recommend running the Monitor Calibration Wizard.
XP w/Nvidia Drivers:
1. Right-click desktop > Properties
2. Click the 'Settings' tab
3. Click the 'Advanced' button
4. Click the tab with your video card model
5. Click 'Start the NVIDIA Control Panel'
6. On the new window (in the 'Display' tree): Run display optimization wizard
7. Finish the wizard and you're "done."
You can also right-click the NVIDIA icon in your system tray, if its there, and open the NVIDIA control panel from there. This will take you directly to step 6.
That's the quick and dirty way to do it. Obviously if you know someone with a Spyder, then that would be the best way...
In 1680 X 1050 60 I can´t see my start bar in Vista and in the top of my screen I see a black line so I suppose that I have to move the screen up with the imagen adjustments but I just cn´t, I just see my background but not the bar below , What can I do , even factory setting doesn't solve this, I just have to return to 1600 X 900 and I don´t like that resolution I used to have 1680 X 1050 but now I can´t not even restore system resolve this
It should subtract the additional $50 from $283.99 when you checkout. If it doesn't then contact Amazon directly before actually confirming your order onlinThe.
Thanks very much for the quick reply, gonna try it
wtf? i am at the check out screen and heres what it says
Items: $283.99
Shipping & Handling: $23.98
Super Saver Discount -$23.98
Total Before Tax: $283.99
Estimated Tax: $23.78
Order Total: $307.77
didn't subtract the 50$
did yours go through?
http://www.biggersale.com/hp-w2207h-22-widescreen-lcd-monitor/Click Here You Save $124.01 + $50 (Extra)
Man it's hard to believe I bought this in January at Staples for $254 out the door...
From everything I've read & seen, the w2207 & w2207h are essentially the same, with the exception of replacing the DVI port with an HDMI port.I am contemplating purchasing another one of these HP w2207 monitors for a dual monitor setup. The one I currently have is the w2207 and I noticed that HP released the w2207h version recently. Does the "h" version provide any significant changes aside from swapping the DVI port for an HDMI port? Basically, I can buy either version (h or non h) for about the same cost. The way I see it, the only difference in getting the "h" version is going to force me to buy an HDMI-->DVI adapter and that's it.
Any comments or ideas on this?
My Samsung 2232BW+ sucks. When viewing white the right side is yellow and the motion blur is making me sick. Colors are washed out as well no matter what I try. I even tried MagicTune which didn't help at all. I didn't get a Samsung panel either which probably explains it. It's an AU Optronics panel.
When I take this hunk of shit back I'd like to get the w2207h. If I look on the box I should look for STMXXX correct? Even the other panels would probably be better than the 2232BW+.
Anybody?
How does the w2207h or w2007 compare with the Samsung 2232BW+ as far as color accuracy and detail?
On my Samsung when contrast is below 70 I start to see banding and artifacts in reds and pinks sometimes blues as well. It looked better in the store but of course that means hardly anything when comparing an LCD for home use.
I edit photos quite a bit(in my opinion). Maybe 200-300 per week and watch movies.
One thing I absolutely hate about my Samsung 2232BW+ is the backlight bleed. The darker scenes don't really bother me but rather the white scenes, even Google's home page where the outer edges especially on the right side are yellowish instead of white. Anything like this on the w2207h?
