The DarkBlade
- Jun 8, 2001
Allaxul said:I think you're right about the wattage requirement but 15 * 8 is still only 120W. I'm planning on at 500W power supply minimum. I don't think it will be an issue.
Well, not exactly. Note the "12V" in the EPS12V specification. You've got one line from the 12V signal going into your motherboard. Then all your molex connectors to your drives and your fans are on the 12V signal too. Basically what I'm saying is that the entire 500W is *not* available to your hard drives, even if nothing else was plugged up to it.
Basically, Watts = (Volts x Amps). So you can have a 500W power supply with 15A on your 12V signal supplying a measly 180W. In this case, you would have power issues for sure.
So it's fine as long as you get a power supply with plenty of 12V amperage. But most of the power supplies that have the amount of amperage you need are going to be "pricier" anyway.
