lmaro said:My brightness is set to 0% most of the time, except for 50% for games and movies. The flickering looks like under/overvoltage to the backlight ocassionally. It is less noticable at higher brightness levels, but I like the brightness low.
This isn't the standard panel flickering. I can sometimes temporarily get rid of the problem by power cycling it or tapping the monitor edge. If the problem persists I'll call Viewsonic and ask them to replace the backlight.
I am about to order one from zipzoomfly because newegg is sold out. I think they just forgot to change the contrast ratio.danyal711 said:Yah it says 8ms but the contrast ratio says 600:1 and for the new one its 800:1... most likely they just havent updated it but I am still skeptical... any other places?
Arkanian said:I am about to order one from zipzoomfly because newegg is sold out. I think they just forgot to change the contrast ratio.
I have ordered stuff from zipzoomfly and they are as good as newegg. Dont know about their return policy on dead pixels. I might call them to verify the specs before I order to make sure that it is the right LCD. I am think that they forgot to change the specs. Blame this on viewsonic for naming a new LCD with the same model name as an LCD that came out like 2 years ago. go figure.ASmith said:Let me know how it goes I am also in the same boat. I would rather order from newegg but I need the monitor right now. I've never ordered anything from zipzoomfly, what is their dead pixel policy on lcd's? I'm also a bit woried about the specs they have listed.
Arkanian said:I have ordered stuff from zipzoomfly and they are as good as newegg. Dont know about their return policy on dead pixels. I might call them to verify the specs before I order to make sure that it is the right LCD. I am think that they forgot to change the specs. Blame this on viewsonic for naming a new LCD with the same model name as an LCD that came out like 2 years ago. go figure.
EDIT: looks as though the ETA at newegg is 6/27. I decided to look at the Samsung 193P+ but newegg and zipzoomfly dont have it plus it is 600 ouch. Now you have me wondering if the zipzoomfly LCD specs are right. I am going to send them an e-mail right now about this.
Arkanian said:This is the e-mail that I sent zipzoomfly
Zipzoomfly:
On your website you state that the contrast ratio for the Viewsonic VP191B is 600:1. You also state that the response time is 8ms. Now me and some other guys at hardforum.com are confused by this because viewsonic made a new LCD that is named VP191B with 8ms and 800:1. This replaces their old VP191B which had 16ms and 600:1. Now are you selling the new LCD or the old one. Me and another guy on hardforum.com are about to order this LCD and we want to be 100 percent positive that we are purchasing the new VP191B and not the old one. Thank you for taking the time to help us out on this matter.
Pixel Policy:
http://www.viewsonic.com/support/qa.cfm?topic=lcd&question=01
ViewSonic sets limits on 17" - 19" LCD's at 7 bright sub-pixels, 7 dark sub-pixels, or a combination of 7.
Zipzoomfly:
http://www.zipzoomfly.com/jsp/Service/Return.jsp
CPU | Hard Drive | Memory | Monitor
* Arrangement for a return must be made within 15 days from the date the item is shipped.
* 15% restocking fee applies to all refunds.
o Per State of California regulations, any taxes refunded in this case will be calculated based on the final refund amount minus the 15% restocking fee, not the original purchase price. Please refer to http://www.boe.ca.gov/pdf/reg1655.pdf for further information.
* Products that are defective, and/or DOA (Damaged On Arrival), can be returned for repair / replacement.
* All returns must also follow the return procedures mentioned above.
* Overclocking or improper installation of CPU fans will cause CPUs to chip or burn. All chipped and burnt CPUs are considered physically damaged and are not eligible for replacement or refund.
______
I should have somthing from zipzoomfly by tomorrow.
Arkanian said:E-mail Zipzoomfly sent me:
Dear Customer,
Thanks for contacting ZipZoomFly!
I have asked the buyer about this item, our ZipZoomFly part number 231744. I
have been informed that we carry the latest version.
Should you have any further questions, please call 510 739 1890 x2200.
Regards,
ZipZoomFly
lmaro said:I think I got my backlight flicker problem figured out. It's a common problem with CCFL lamps running at low voltage, and I don't think ViewSonic tested it much at 0% brightness. 5-10% brightness, and the flicker goes away. I'll update this post if anything changes.
It's called backlight bleeding. Doesn't seem bad in your case, but in some cases it can be bad enough to warrant a replacement.|Leviathan| said:the only concern Ive got is *I don't know what to call it* but when I just output a black bkground on the monitor i.e.: nothing else just total black, on the lower corners there is a sort of light glowing
