Ray Sheppard
- Apr 15, 2005
Spent some time deciding which LCD to buy and finally bought a VP201s from SCAN (today only) yesterday for £590 delivered including VAT. I was pleased with the price and happy with the purchase but listen to this tale of woe.
My 3rd 22" IIyama 514 Pro, in just over a year, was on the blink again and I bit the bullet and bought the ViewSonic 201s LCD. The IIyama was set to 1600x1200 - refresh rate of 85 when it went on the blink and when I installed the new ViewSonic 201 a message appeared on the screen Out Of Range. I guess that was the IIyama refresh rate of 85 causing the problem and tried a reset to safe mode to alter the settings. The screen display was excellent in safe mode but I could not access my Radeon X800 Pro card refresh rate settings from safe mode.
I used the two buttons on the front of the monitor - the 2 and the up arrow held in together and a message popped up saying 1600x1200x60hz so reboot thinking all would be fine but the Out of Range message was all I got. I rang SCAN first and was told to check the guide on the CD as the guy I spoke to had no idea how to fix it. No mention of the Out of Range message in the manual so I rang the ViewSonic main help number found in the manual. That was an absolute joke. The lady I spoke to at great length spent 10 minutes collecting all my details and the Monitor details before putting me on hold to check with somebody else. The fix it method I was told - if I didn't have another Monitor to use to change the refresh rate borrow one from a friend. I asked to speak to the techie dept and she told me to use the VS web page and send an email.
I did find the 'fix' myself and it turned out to be simple. Hit F8 during boot and instead of using safe mode use VGA mode and then I was able to access my video card display settings and set the refresh rate to 60 - all OK now.
The VP201s so far - superb - can't fault it in any way - just a shame I had no techie support.
Ray
Ray
