so you actually think that having a video card at 200 degrees Fahrenheit has no effect on heating up a room?? thats not even taking into consideration all the other pc related hardware. I can tell you that hell yes a gaming pc with a hot running gaming card can have significant bearing on room temperature.I increased the OC on my card, and now my whole house is hot. I ACTUALLY HAD TO TURN THE A/C DOWN GODDAMN U ATI...
I just re-read some of the comments defending the "my card heats up the room" arguments.
"Please get a life..." - God
I think the difficult part to understand is that the TDP of the 9600GT is ~100 watts, and the TDP of the 4870 is ~160 watts (according to a quick google, unconfirmed though).
You're suggesting that a 60 watt increase in heat output has managed to overpower your AC...
Sapphire 4870 @ 800 / 1000
Stock cooler.
Highest load temp I have seen is 76C.
Idles @ 60.
I've done nothing to control the fan so I assume its set to auto.
Needless to say the temps are fine and the card is quiet.
Thanks man, that's all I was trying to say.
Well I did not know that someone had to have a Masters degree in a specific field to realize 200 degrees was hot. Next time somebody bitches about it being 95 degrees outside I will question their educational background.That really wasn't a statement you want to stand behind.
The combination of epic fail and logical thought in this thread is making my head hurt.
OP, if your Master's Degree is in anything even remotely technical, I would like to know what school you received it from so I can sue them for some form of educational malpractice.
If this thread doesn't abuse you enough, try explaining the difference between temperature and windchill to someone.The combination of epic fail and logical thought in this thread is making my head hurt.
These newer graphics cards need better stock coolers and the ability to step-down ( like CPUs ) during non-gaming situations.
Hey, I'm reading this post and it's funny some of the comments.
Yes, I know this room is freaking hot, I've had AC technicians even increase the size of the duct going to it. It's my office, I agree that's my first problem; but I still can't believe all the insults about my intelligence because the fact the room heated up noticeably after I got this card and so I returned it.
simple.
My plan is to wait until the refresh and some new products hit, watch prices fall, and eventually if I might have to I'll deal with a hotter card. But there better be a decent game out there to use the card on since I don't really need an upgrade anyway and I've actually got this room pretty well balanced.
And to you who wished me well on the Velociraptor, thanks. That is one smokin' HD! I partitioned about 220gb for programs and 80 for VISTA, got all my pics, music etc. on the second partition and it's really nice.
And also how much heat it is dumping OUTSIDE the case. Slot blower heatsinks push all of the hot air out of the case, while single slot blowers or downward-blowing heatsinks keep a large portion of the hot air inside the case.NO. The idle/load temp of the card is COMPLETELY IRRELEVANT. The *only* thing that matters in regards to heating up the room is how much heat it is producing, *NOT* at what temp it is at.
Not going to make much difference. The case will quickly reach equilibrium; if it's a few degrees hotter inside with a different cooler that heat still ends up getting radiated into the room. Where else is it going to go?And also how much heat it is dumping OUTSIDE the case. Slot blower heatsinks push all of the hot air out of the case, while single slot blowers or downward-blowing heatsinks keep a large portion of the hot air inside the case.
Still...a single video card should not produce so much heat such that your AC can't keep up and you have to return the card...
QFT.
I have never experienced such a radical change in room temperature due to a video card. Frankly, I have a hard time believing that.
You really need to learn how to use multiquote....... 7 damn times ...
You strike me as a middle aged, very grumpy man grumbling about things out of his control or most things inconsequential.... but grumbling nevertheless, LOL.
Thanks but my life's just fine.
oozish said:I could feel the heat increasing in the room within about 5 minutes...I was like, "no....I can't believe I can tell the difference!"
Ah well...this room gets hot enough anyway, in TExas u know...100 plus all week here.
QFT.
Honestly, some of you have never taken physics a day in your life...
looks that way........seems to me the only RELEVANT temps should be taken at the system exhaust...
The average human, when sitting, outputs between 70 and 130 watts of heat. Are you saying that you don't allow visitors in your room because they make it unbearably hot?
(source: http://ergo.human.cornell.edu/studentdownloads/DEA350notes/Thermal/thcondnotes.html)
Second, heat dissipation: the temperature of an object has nothing to do with how much heat the object is putting in your room. The difference in temperature between two adjacent materials determines how quickly heat will transfer between them, but nothing more. If you fire up your video card, it starts at room temperature and begins to heat up. Unless you're rich, or you've got a card that doesn't generate much heat, your cooler will not be able to keep your card at room temperature, so your card will begin to heat up. As it heats, your cooler will be able to dissipate more and more heat from the card, because the temperature difference between the card and the surrounding air will increase, thus improving heat transfer. Eventually, the card will reach a temperature where heat transfer has increased to the point where your cooler is dissipating as much heat as the card produces. A card that was putting out 100 watts of heat with abysmal cooling (i.e. passive, crappy heatsink) could easily heat up to 100C+, whereas a card with 200 watts of heat could be cooled to 45C with a good water cooling setup. The 200 watt card is still obviously going to make your room warmer than the 100 watt card, but it's at a lower temperature.
Slightly more in depth science: heat is a measure of energy. If an object is at a certain temperature, that temperature is simply a measure of how much thermal energy the object contains. There's no way of knowing how much heat is being dissipated from an object just by knowing its temperature. Watts, on the other hand, are a measure of power. When an object is dissipating some amount of watts, it's generating a constant stream of energy that will heat up itself and everything around it.
Or, in simpler terms, when you're buying a space heater, do you check what temperature the coils heat up to, or how much heat (watts, or btus) gets put out?
