w1retap said:No.. I didn't need any other 'special' drivers under Windows XP SP2 for it to work. I just plugged it in and started watching movies. The only thing extra I installed was the toshiba driver hack that enables UDF2.5 file system so you can browse the file structure and easily rip the disk to your hard drive.
err..say what? DVI to HDCP? there is no such cable. HDCP is a content protection protocol that uses hardware handshaking to ensure a secure digital connection for 1080p viewing. But, from what everyone says, you don't need this right now to watch HD-DVD's. It should work on anything, even a VGA cable, or component cables.-h2o- said:to get HD DVD running on your computer did you need a DVi to HDCP video cable? or normal DVi - DVi or VGA to VGA
i have a similar setup but only a 26" samsung screen at a native res of 1360x768
w1retap said:You just right click the .ini file and select "install" after the drive is plugged in, then you restart your computer. After you do this, you can browse the file structure, get the AACS encryption keys, and backup the disks. I'm have both HD-DVD's backed up on my HDD right now, but I'm just trying to figure a way to encode them to x264 for a smaller file size.
3.3.2 Encryption and Decryption of Title Key
Title Key File Set consists of three Title Key Files. Each Title Key File within the same Title Key File Set shall
have the same value of Title Key. Each Protected Area Key (Kpa) is encrypted by Media Key (Km) and
associated Binding Nonce. For each Title Key File, associated Binding Nonce (Binding Nonce_X, Binding
Advanced Access Content System: HD DVD Recordable Book
Revision 0.921 Page 40
Nonce_Y, Binding Nonce_Z) within the same Title Key File Set takes different value. Each Title Key (Kt_X ,
Kt_Y, Kt_Z) stored in each Title Key File (TKF_X, TKF_Y, TKF_Z) shall be encrypted by its own Protected
Area Key, Title Key File Nonce (TKFN) stored in other Title Key File (TKFN_Z, TKFN_X, TKFN_Y) and
Usage Rule corresponding to the Title Key as follows:
Kpa_X = AES-G(Km, Binding Nonce_X), Kte_X = AES-128E (Kpa_X ⊕ TKFN_Z, Kt ⊕ AES-H (Usage
Rule))
Kpa_Y = AES-G(Km, Binding Nonce_Y), Kte_Y = AES-128E (Kpa_Y ⊕ TKFN_X, Kt ⊕ AES-H (Usage
Rule))
Kpa_Z = AES-G(Km, Binding Nonce_Z), Kte_Z = AES-128E (Kpa_Z ⊕ TKFN_Y, Kt ⊕ AES-H (Usage
Rule))
where AES-G represents a cryptographic one-way function based on the AES algorithm as defined in the
Introduction and Common Cryptographic Elements book.
and AES-128E represents encryption by the AES cipher with the Electronic Codebook (ECB) mode as defined
in the Introduction and Common Cryptographic Elements book
and AES-H represents a cryptographic one-way function based on the AES algorithm as defined in the
The process to decrypt Title Key is as follows:
Kpa_X = AES-G(Km, Binding Nonce_X), Kt = AES-128D (Kpa_X ⊕ TKFN_Z, Kte_X) ⊕ AES-H
(Usage Rule)
and AES-128D represents decryption by the AES cipher with the Electronic Codebook (ECB) mode as defined
When you run a pure digital signal out like coaxial or optical, your reciever does the decoding. That might mean it will only decode in DD5.1 or DTS. I think in my case, the computer software, specifically the PowerDVD software is decoding the Dolby HD and outputting to my speakers. If you run straight optical or coax digital out from your sound card, the computer doesn't do any of the decoding.sj41 said:Hmm does this mean that in order to play DTS/DD tracks, I should let my audigy decode OR run coax to receiver and let that do it, while for TrueHD tracks I should let the software (powerdvd) decode and use the analog cables (green/black/yellow)? But what if my receiver doesn't them? (this is the receiver I'll be using: this)
w1retap said:When you run a pure digital signal out like coaxial or optical, your reciever does the decoding. That might mean it will only decode in DD5.1 or DTS. I think in my case, the computer software, specifically the PowerDVD software is decoding the Dolby HD and outputting to my speakers. If you run straight optical or coax digital out from your sound card, the computer doesn't do any of the decoding.
1) I'm not going to speak of title keys on a public forum.figgie said:w1retap
have you or have you not gotten the Title keys (at least the one needed for this workaround)? That would be the first question.
the second question and most pertinent. Are you prepared for the Xbox HD-DVD to become an expensive DVD player when connected to the PC?
Piracy? We're talking about "backups" here!
