I bought the E3110 from Buy.com last week and we got it in last Friday. It's socket LGA775. All Xeons that are 3XXX are socket 775 chips.
We put it in a GIGABYTE GA-P35-DS3L rev 2 board and the system fired right up, recognized the CPU properly and ran at the correct 3 ghz speed. It worked fine on the BIOS it shipped with but we updated it to the latest one. Just setting the FSB to 400mhz had it running at a stable 3.6 ghz. Core temp and Speed Fan give funky looking temps (AC7 pro cooler, properly seated, Antec 900 case). The temps are about 10 - 15 degrees higher than I think they should be: 56º C running Orthos @ 3.6 ghz.
You are absolutely correct about them being the same processor...although they have raised the price on yours to just a tad under $210 ($208.70).
What I'm interested in finding out is your processor's batch code. What did you receive?
From posts that I've seen, Buy.com is shipping Q746A534 to the people that bought the "LGA775" E3110s. Since you bought the one listed as a Socket 771, I was just curious as to what they shipped you.
I realize that it should be the same, but just want it confirmed.
Does anybody know if Nvidia 680I LT will support the E3110? I checked the CPU support list on their website and they do not have any Xeons listed but I know they may of just not tested them.
It's an XFX 680I LT board, says there is a 45nm cpu bios available. I'm parting out my current rig which has a 6300 core 2, so i'll drop that in, flash, put in new cpu and good heatsink.If you can find a Wolfdale compatible BIOS for the board you should be ok.
Keep this quiet guys, don't go telling everyone or we won't be able to find these either.
Buy.com is sold out now.
In fact, I can't find these anywhere! Nuts.
Edit: $218 shipped at ComputerHQ.com, found it through cnet shopper.
Incorrect. The micro-code is very different. Not all motherboards will work correctly with the Xeon LGA775 CPUs if they don't recognize the micro-code of the CPU.
good luck...mine hasn't cancelled yet...so here's hoping.After ComputerHQ bailed on me I tried TechMicro. Their site showed 'em in stock. A few hours later, they canceled me.
I just ordered from Tankguys. Here's hoping they don't pull the same thing!
Already have the motherboard, ram, and everything else ready to go
Intel lists the following under "Other Intel Technologies" for E3110:
http://compare.intel.com/pcc/showchart.aspx?mmID=893558&familyID=5&culture=en-US
Execute Disable Bit,
Intel® 64,
Dual-core,
EIST,
Intel® 64ø,
Intel® Virtualization Technology
And for the E8400:
http://compare.intel.com/pcc/showchart.aspx?mmID=33869&familyID=1&culture=en-US
Intel® 64,
Enhanced Intel SpeedStep® Technology,
Intel® TXT,
Execute Disable Bit°
There are other differences too like "sSpec Number", memory typed (only ddr2 for 3110?) ans chipsets. I don't know if this means anything.
thats great news as i was about to buy same board and have been hunting for a e8400 so I guess I can get the Xenon now and save a few bucks, ThanksFor anyone who's interested, I got mine running on a GA-P35-DS3L right out of the box, no problems, so these things really should work on anything that already supports an e8400.
Got my E3110 labled as a 771, anyhow it shipped from CA and is the same as the rest, Q746A534 01/16/08.
I'll probably pop it in tomm afternoon and see how it compares to my E8400.
Gotta say 1 thing, bought this at buy.com Saturday late afternoon for $198.00 and the darn thing was at my home this afternoon, fast shipping.
Larry
Xeon is the correct name of the processor. Xenon is a element often used in the making of lights.
I got my e3110 and got it installed yesterday on my asus p5n-d mobo.
coming from system in my sig, I notice no in game differences in COD 4. Something isn't right....
Unless its supcom
If you thought the CPU was going to make a big difference in COD4 you are sadly mistaken. Games are generally going to be GPU limited not CPU limited.
well it shouldn't make it WORSE going from a 2.2ghz x2 4400 to a 3.0ghz c2d and going from ddr 400 to ddr 2 667 or 800...
It stayed about the same for in game performance. I still believe going from that proc to this one there should be some difference in game performance since I have buddies that have the same video card as I have but processors faster than the x2 4400 that have alot better performance than I'm getting with the wolfdale...
Normally it boils down to system configuration or configuration of in-game options, or video control panel options. Its' either that or a driver issue somewhere.
I believe it is a driver issue or a bios options issue. Or a memory read or cpu read issue. Maybe CPUT not installed correctly. Maybe ram not high enough speed. I'll troubleshoot further when I get home.
Would one of these work in a Gigabyte P35 DS3L motherboard?
