Hello everyone, after lurking here for some months now, I've finally decided to register
At the moment I'm using an old 19" CRT that lost its flair. Upping the contrast makes colours reasonable, but everything blurs to hell. No matter what I do, dark shades of gray cannot be displayed. The monitor, while good for general type of work, doesn't cut it anymore, especially not since I recently bought a DSLR and am doing some very amateurish photo editing. Nothing fancy, nothing to go in print.
So, I need a new monitor.
Things I should mention:
* I'm using this CRT at 1280x960, wouldn't like to go lower regarding pixel pitch
* Can't find decent CRTs in good shape
* I'm from Croatia, and monitor choices are very slim here, plus everything is expensive
* TN doesn't bother me much (shock, horror)
* PVA is out, kills my eyes
* IPS isn't widespread
* I don't have a calibrator, nor know anyone who has one, nor the money to buy one
* Not a gamer
* Need the display to be very, very dim in the evening; VERY dim
That's a short summary
Regarding the first point above, I did some simple calculations and found out that a 24" LCD at 1920x1200 will have slightly smaller pixel sizes than what I'm currently using. I could probably live with it, though a 26" (25.5", actually) would be equal to my CRT.
I'd probably be happiest with another CRT, but I can't find any good ones. My next choice would hence be an IPS monitor, but like I said, there isn't much of a choice. No Hazros, no Planars, no DoubleSights, no NEC 2490... I can only get a super-expensive and "small" 23" Apple Cinema Display, or the new HP 2475... Which brings me to my next problem: I'd very likely have issues with wide gamut.
I've narrowed down my choices to the following (prices in US$ for easier comparison, since most people here seem to be from the States):
HP LP2475W: $1020
Pros: H-IPS
Cons: wide gamut, smaller pixels than on my CRT
Benq V2400W: $700
Pros: fairly accurate colours by default
Cons: TN, smaller pixels than on my CRT
Samsung 2963HM: $920
Pros: 26", equal pixels to my CRT
Cons: TN, almost as expensive as the HP
Samsung T260: $900
Pros: 26" (as above), looks pretty
And yeah, the US$ prices above are accurate, it's not a mistake. The NEC 2690 would cost $2000
To be honest, I'm leaning towards the 2475, but I'm not sure if the cons will outweigh the fact that it's the only readily-available S-IPS of decent size here. If it wasn't wide gamut, I'd jump right on it, but I have a feeling wide gamut would drive me crazy. I usually like my colours muted, not vibrant.
Now, I did say that TN doesn't bother me much, but it still does. I've never worked on a TN that's so big, so I'm guessing that the vertical shift would be more pronounced than on smaller monitors. If I'm spending ~$1000 on a new display, then I'd like it to be at least close to my CRT back in its old days of glory, and not unable to display a solid colour without a gradient...
Any ideas about what to do? Things would probably be a bit easier if I could stand PVA, but I can't.
* Not a gamer
HP LP2475W: $1020
Pros: H-IPS
Benq V2400W: $700
Samsung T260: $900
