BillParrish
- Aug 25, 2006
Sorry I havent found a source for the pushpins. I replaced mine with nylon 4-40 size (#4 screw 40 threads per inch) from the lowes specialty hardware drawers but you have to be able to get to the bottom of the board to install them. No idea of what that would be in metric. 3/4 to 1 inch in lenght should do find and if long since they are nylon you can snip extra lenght off after washers and nuts are applied.
Thermal pads just do not transfer heat as well from the chip to the heatsink. thats why you see so many references to Artic Silver 5 thermal grease compound. If there is no other choice a pad is better than nothing, and they are much improved over the last couple of years, but for best heat transfer a good grease properly applied is favored.
350 x 2.5 = 875MHZ good OC for memory at tight timings. Much more and typically timings will require loosening up.
350 x 2.66 = 931MHZ thats pushing it even with relaxed timings. Put the memory on auto at the 2.66 divider and see what the board sets the timings at. I would say that failure is ram, but I am often wrong. At high speeds like that (480x2 = 960), my board starts setting speeds like 5 6 6 27 !!!
So hard to say with that 2.66 mulitplier, most likely ram as you have proven the chipset can do higher ( I think, I might be getting posts mixed up, I should be in bed LOL )
350x9 2.5 memory multiplier with 4-4-4-12 timings I can get at least one hour out of orthos. Running 350 x9 on 2.66 mem multiplier I fail after 5 mins even with very loose timings like 5-5-5-18. Thats all chipset related right?
