Seventh_Sliver
- Aug 25, 2010
What do you think of the design?
What would you change or add/remove?
Somewhere between April and June, according to Intel.Sounds like I should definitely wait for Z68 then. Is there a release date?
The design of the Giada H67 ITX is the best I saw so far:What do you think of the design?
What makes my optimistic about this ITX, is that Giadatech received good reviews for its products (mostly mini nettops and atom ITX MoBos), even if I couldn't find any review about the ITX H55...I've become hooked on the mini-pcie slots...
Sorry, I forgot that part. I'll change:What would you change or add/remove?
I would expect a quite affordable MSI ITX SB, nice for low power HDTV systems.We have no plans for a P67 based mini-ITX. Our mini-ITX will be H61.
Hope this helps.
Okay guys,
It has been extremely helpful posting with all of you!
It's time to do some serious work...
I finally broke the ice and went to purchase the hardware for my new
SANDY BRIDGE MINI ITX SILENT GAMING SYSTEM
I'm going to open a new thread about the building.
My components:
Case: LianLi PC-Q08 (black)
MoBo : Gigabyte GA-H67N-USB3-B3
CPU : Intel i7 2600K
GPU : XFX Radeon HD 6950 2GB
Memory : Corsair Vengeance 8GB (2x4GB) SDRAM DDR3 1600 (PC12800)
CPU cooler : Thermalright AXP-140 RT
GPU cooler : Scythe Setsugen 2
PSU : Cooler Master Silent Pro M700
Additional fans : 2x Scythe Slip Stream Kaze Maru2 140 1,700 RPM
Fan controller : Crystalfontz DB635-AKTMF-KU3
I'll post it soon!!!
The "k" CPU is because this system will exist awaiting for a Z68 to come out...Why the k processor with a H67 board?
Quietness and gaming power are a very difficult balance, most of all with this form factor.hmm i think silent is a bit misleading , giggles
Jen
YOU GOT IT!!!they aren't any P67 or Z68 m-ITX boards out. so H67 on a K processor is the only option. Most of us are eagerly waiting for those boards to hit the market and dump the H67
I'm working on a similar build with a Silverstone SG07 case.
You'll probably need to pick different memory; the AXP-140 only has 40.2mm clearance and the Vengeance memory is about 50mm tall.
You are perfectly right!I'm working on a similar build with a Silverstone SG07 case.
After getting rid of the heatsinks, I'm going to place solid copper ram coolers from EnzotechYeah I got AXP-140, 2600K, SG07, and Vengeance, and the Vengeance will not fit with AXP-140(RT). Have to use my old OCZ
I knew that before purchasing the ram.
I made some changes... I need others...
I'll receive these tomorrow and post the result in my build thread.
Yes, I would say.Very good price indeed. That mSATA card connector will allow us to use a wireless card?
1 x Mini PCI Express x1 slot
Supports Mini SATA
Supports Mini PCI Express
Still waiting for a Z68 mitx
I think it'll take a while...Still waiting for a Z68 mitx
WHAT???According to this swedish website, Zotac will release their Z68 miniITX on May 31st:
Zotac Z68 miniITX announced.
Dunno about widespread availability though...
I hope so too!oh damn -- it's on now. hope they keep the full-size mPCIe slot (not the half/vertical one from their fusion board)
Model MI-H67-01
Supported CPU Intel Core i7 / i5 / i3 (LGA1155)
Chipset Intel H67
Memory Slots 2×240pin
Maximum Memory Supported 8GB
Channel Supported Dual Channel
Expansion Slots
PCI Express 2.0 x16
2 x Mini PCIe
Storage
SATA 3Gb/s 2
SATA 6Gb/s 2
Onboard Video Chipset None
Onboard Audio 8 Channels
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 1
1 x DVI HDMI
1 x HDMI
4 x USB 2.0
2 x USB 3.0
S/PDIF Out 1 x Optical Audio Ports 5 Ports
Form Factor Mini ITX Dimensions 6.75" x 6.75"
Power Pin 20 Pin
Sorry to hear that you had to RMA the Giada H55nope, I won't be buying a giada any time soon... they pissed me off by only having a half-height minipcie on the back of the board on their h55 mobo. and even then having chips invade the space set aside for this item
that being said, they're cheap, no ports you don't need, and newegg took the board back w/o restocking fee
I'm waiting for the zotac z68
in the future, you can't just say "2 minipcie"... a minipcie is not a minipcie is not a minipcie. you need to specify mechanical characteristics (i.e. full height vs half height -- in the modern term, not the Eee behemoths) and the electrical characteristics (wired for mSATA vs. wired for mPCIe)
That's a good news!Someone asked Gigabyte about mITX Z68 board. Their answer looks promising..
"we thought it best to ask Gigabyte if they still had plans for a P67-based mini-ITX motherboard. Their response was brief,
No, we no longer have plans. Instead, we will release a Z68 based model.
http://www.itxgamer.com/news/gigabyte-drops-p67-favors-z68/
In the silence of the forums and specialized sitew, the
GIADA MIH67 is arrived and is available at the Egg for $99.99 + $6.99 shipping
Specs:
I suppose this Giada will grab some attention! I'm specifically thinking to Machupo, is that right?
- 2 mini PCIe --> GOOD (the ECS will have 2 as well)
- 20 Pin Power --> BAD
