Mysterae said:Parallel Sex Nice one! Which number is that in the Karma Sutra?
SpangeMonkee said:69 of course.
Mysterae said:Many of the wires arent long enough to reach the fan controller.
Geo Fry said:Mysterae,
Was just wondering if you had tried puting the 2 pumps in parallel yet. I completely agree with Erasmus354 on how the flow is the problem and even if it does become somewhat of a bottleneck when the loop merges into the radiator, who cares... I say give it a try and then test your temps. Maybe even place the 2 pumps in parallel AFTER the rad.
Give it a try... for your components sake, and my interest
I've kept an eye on this and sorry for not saying anything yet but your watercooling loop ideas are awesome and inspiring... keep it up
Mysterae said:Hi guys, thanks for your ideas!
*snip*
n00btard, it's a bit more difficult to put another connection to the rad! The metals not thick enough and would really require soldering to do properly. The solution is easy - the bottom of the collector already has two outlets; [oringally] one for the pumps and the other for the drain. I just need to make them both go to a pump each and put an equal T fitting and valve on one of the lines for the drain. If I do need another rad, then the outlets of the rads will meet before going to to distributor, which I think will really improve cooling performance. If one rad is sufficient then the two flows from the two pumps will combine before the rads inlet.
*snip*
UnknownSouljer, another great idea! If the top up of the coolant could be done safely, you may be on to a winner here. And it would look cool. It couldn't be a solid false ceiling, as not to impede the flow of air to the bottom of the rads. The collector could possibly be placed in the centre of the case too. Thanks, I'll have a muck around with Sketchup and see what's possible! However, the ease and safety of topping up with coolant is paramount, and it's going to be tricky with the DD fillport of the collector to be accessible.
All being well I'll have an update for you on Friday!
