vapb400 said:SUBSCRIBED!
This looks amazing!
ibid
This looks amazing!
themark said:You mean the shaded resevoir on top of the white components? Um... Photoshop? Either that or you colored everything, except the Rez, white. Transparency in this program is just silky isn't it? I'm using it right now to build a display for our trade show. Gotta learn it fast.
Another bit of lingo I'm not famillar with, but thanks (I think)!jakedeez said:ibid
Mysterae said:Plan of action now is to benchmark the system for temps for idle and load while on air so I can compare temps when on water.
Mysterae said:Duely noted Erasmus!
I've been busy taking the pc apart and test fitting the waterblocks. I have posted a preliminary review of the Aqua Computer hardware in the Water Cooling Forum that may be of interest to many.
Here's a teaser shot until the next update:
[.IMG]http://homepage.ntlworld.com/mysterae/parallel_hex/stage_93.jpg[/IMG]
Gongo said:just a quick question... will you have water flow problems? with so many things all linked wont there be a path of least resistance?
bail_w said:Temperature are too high for that ambient temp.
bail_w said:Your Cpu Temperature peak full loaded @ 58 degree
