Please enlighten me on what software/procedures I need to "fix" my cards....especially the RAM timings, I don't understand videocard RAM timings nor do I know of a way to edit them....HeavyH20 said:Well, a bit of good news. The card I just got from RMA seems to be working fine. I edited the BIOS to reduce the throttle clock to 600 from 630, loosened the memory timings back to Samsung spec, and reduced the memory clock in 2D to 650 from 800 (why heat the memory browsing the web). I kept the 50 Mhz delta and stock 3D clocks of 690/880.
With those changes, I looped the last testof 3DMark06 50 times without any artifacts, hiccups or odd behavior. It scored 29.4 fps average for the 50 runs at default driver settings. Not too bad.
I will do another run, verify it works then flash the card back to stock SC. Then, I will see what the stock BIOS can do.
blurp said:Question to owners of Dead 7900 GTX : How long did it take to die ?
I've had mine for 1 month working flawlessly. I can push my PNY at 690/880 without a hiccup but usually keep it lower (675/875). Ran many times 3dMark06 fine. So I guess I got a good specimen even though the delta is 50.
Sovereign said:Please enlighten me on what software/procedures I need to "fix" my cards....especially the RAM timings, I don't understand videocard RAM timings nor do I know of a way to edit them....
HeavyH20 said:Well, just looped the last test of 3DMark06 for 3 hours. No artifacts, no issues. So far, so good.
HeavyH20 said:If you use Coolbits, I see two different speeds. 650 for 2D and 880 for 3D.
As for the core, with a 50 MHz delta, it seemed 630 was a little high for a 650 norm. I made a 50 MHz difference to 600 to allow the throttle to actually have the right effect. Also, the memory throttle is now 750 versus 800. Just in case. I set the memory spec to Samsung 1.1/1.2 ns spec, as well.
I will loop it overnight and see what happens.
dR.Jester said:My Battlefield 2 just started doing this tonight. After I thought everything is fine, BF2 starts f'ing up BAD!
http://www.laidbackcrew.com/gallery/files/2/7/1/Image2.jpg
This freaking sucks, and guess what fixes it? When I alt-tab out of the game and come back, no more problems but when they do start to happen is annoying.
jacuzz1 said:May be its too early but at the very least I think the issue has reached a level that perhaps Kyle and the boys could do an article on it to bring more attention to the problem
KJ43 said:Exactly what I was thinking.
At this point, I don't know that I can get a refund anymore since I am doing the RMA directly with BFG instead of newegg.
