flat4 said:pics????????
DaMaDo said:Cornelious, just wanted to double check with you since you're familiar with all the CSP pump stuff...I have several items my water cooling system to cool and wanted to confirm whether I shold go series or parallel. My understanding it that parallel both pumps are next to eachother with a Y-divider on both intake and outflow and Series is that the other pump is somewhere else in the loop helping the flow along.....so series or parrallel? =)
cornelious0_0 said:Go with series for sure. With parallel you gain a BIT more GPH then you do with series, but parallel doesnt really increase your max head length, which can be MUCH more important.....as 300GPH means nothing if the pump has a low head length rating, as its flowrate will soon diminish. Putting two CSP750's in series not only gives you a healthy boost on the GPH by about 10 or 15 or so, but it literally doubles your max head length, to about 146 inches.....which is roughly twice as long as even the mighty Eheim 1250 can muster.
I'm still undecided as to whether or not I'm going with two pumps, depends on cash this month.....but I gtg, my 3.4E is being delivered in teh next 2 hours or so and I wanna be upstairs waiting for it.
Alienraptor said:Would it be a hassle to get something shipped from bigfoot to the States?
Alienraptor said:That's cool. Thanks for the info. Is your loop set up and ready to run or has the 3.4E not arrived yet?
Alex41290 said:good luck, and you should congratulate customs on the "speedy" passthrough of your 3.4E...
HeavyH20 said:NAFTA really helps get the PC parts through Canada customs these days.
I am patiently (NOT) waiting to see what that processor really had for potential. Now that I know the RAM was the issue, there could be all sorts of undiscovered potential on the that CPU.
BTW, the CPU idled at 43C on my Abit IC7-Max3, but those were notorious for innaccurate temps. It would load to around 51C, but, then again, that was Abit measured temps. I suspect they were lower by around 8C or so.
pics anytime soon?
you should look into a Storm G5 for maximum OC potential.
Alex41290 said:http://www.employees.org/~slf/lrwb/
its Cathar's site, and he makes some of the best (and most expensive ) blocks EVAR!! (i know its spelled wrong, but it enunciates the point)
u'll hafta contact him to get one, and you can email them (i think) to ask about it. its on the contact us section of the site above...though, good luck getting one...i wouldn't look for a G5, cuz he said that his machinst can't get them out till Q1 2005, unless you're gonna be looking at one then...but expect to pay about $96USD + $10 for shipping.
so, if you wanted to do that, go ahead, but i'd recommend a pelt. before spending that much on a waterblock that probly won't improve ur temps more than 4 or 5 degrees.
I bet you would see a nice improvement in your overclock if running a Storm G4 or G5 over the TDX. Bad part is I don't think anyone will see one for a good month until his orders are filled. I had a G4 off his first batch and found it to be an incredible block and the G5 is supposed to be better.cornelious0_0 said:Personally I think I'll hand onto the TDX for now and leave it at that. After this setup is completed I'm going to be looking at switchin to a Phase Change setup by spring, so I'm not gonna spend TOO much cash on this h2O.
R1ckCa1n said:I bet you would see a nice improvement in your overclock if running a Storm G4 or G5 over the TDX. Bad part is I don't think anyone will see one for a good month until his orders are filled. I had a G4 off his first batch and found it to be an incredible block and the G5 is supposed to be better.
R1ckCa1n said:I am very interested in phase change as well but am not sure if the noise is worth the $. If I could find a silent phase change solution, I might dive in too!
DaCoOlNeSs said:where in Canada do you live cornelious0_0?
I used to go there for a visit every year, but since my grandpappy died, I have no reasoncornelious0_0 said:Saskatoon, Saskatchewan yo.
DaCoOlNeSs said:I used to go there for a visit every year, but since my grandpappy died, I have no reason
I'd never convince my parents to take me there too look at a PCcornelious0_0 said:I'm not a good enough reason?
DaCoOlNeSs said:I'd never convince my parents to take me there too look at a PC
they would be like "you have one in your room, thats good enough"
heh, same here.cornelious0_0 said:I hear that, mine are the same way....the only way I get away with most of this is they don't even know about half the shit I buy for this thing.....I would have been disowned years ago.
Alex41290 said:I'm lucky...for some reason my parents don't really mind buying me computer stuff...but I almost always hafta pay for AT LEAST 1/2 of it...sometimes all but like 50 bucks or shipping...maybe they pay for all this stuff cuz i'm really retarded or have some brain disease?
