What I want to know is if they fixed the backlight buzz issue for the 3008. It was a clear and cut design flaw with the 3007, where at higher brightness levels the monitor omits a high pitch squeal. Different monitors squeal different amounts; I went through 4, and 2 were unacceptably loud, while the one I stuck with is nearly silent at two clicks below max brightness. By far the worst problem with this monitor.
Yes, now it's polyphonic, with six preinstalled melodys. That's why it cost over 2000What I want to know is if they fixed the backlight buzz issue for the 3008
I just tried the lowest setting. It's perfectly usable and not that dark, but the colors become a lot less vibrant and white becomes gray. On this display, colors are so brilliant that I want the backlight as bright as it goes.How are they at min brightness? I find them too bright for the most part and won't use anything near max brightness. In fact I will probably have it on minimum.
Well, the brightness of the backlight affects both brightness and contrast.You'd think the colors would begin to wash out as you increase brightness past a certain point...
Haha, funny stuffYes, now it's polyphonic, with six preinstalled melodys. That's why it cost over 2000
Sounds annother thing to want. I feel like replacing my 3007 (original) in the near future anyway.
I'm still very happy with my 3007WFP. I also like the HC version but they can keep their 3008WFP if it has a glossy screen and or input lag.
Why the hell does anyone care about scaler chips?!?
the Nvidia driver have had resolution scaling built into them since as long as I can remember,
In fact I've read reviews of the 3007 that slate the monitor for lack of controls yet all this stuff is easily accesable through the Nvidia display settings panel, and offer probably greater control over the display characteristics, obviously physical brightness needs to be changed on the monitor but this is possible on the 3007 anyhow.
the only single downside of the 3007 is the inputs, and to be quite honest most of the rest of the other inputs cannot power the native resolution of 2560x1600 anyhow.
Why get a monitor so high resolution if all you're going to plug in is low definitions consoles into it?
Besides all other inputs can be piped through your computer.
And you paid about 1/2 the price.
Why did you choose the Samsung over the Dell 27 in.?
How good/bad is it with VGA input?
I am debaiting the same question. Should I wait for the new 30 inchers to come out and then wait agin to see which one is the best, or buy a 27 in. and save a bunch of money in the process.
Thanks
Dave
G'day,
I'm from Australia and I received my 3008 on Friday. As far as I can tell this monitor is brilliant, and is definatley in a class above the 2707 I upgraded from. It is NOT a glossy screen, and there is nothing wrong with the scaler from what I have seen thus far. 1080p can be displayed over component.
The only minor issue is for some reason it does not display 1920x1080 properly over VGA from my XBOX 360, however this is probably because of the XBOX rather than the monitor.
G'day,
If you people are just watching movies, playing games, using Xbox or Playstation or surfing the internet. Don't even waste money on 2k for a 30' LCD. For that price you would rather pick up a 40+(1920x1080) inch LCD TV.
IF you are a graphic designer, it's a whole different story.
I'm not terribly impressed.
Popeyes Chicken's Fucking Awesome!
What's the dealio with the XBox over VGA? What resolution is your XBox set to? Vrey strange. Is it basically unusable with the 360 over VGA then? I see above that you set your xbox to 1920x1080, have you tried setting it to any other resolutions to see if they work? It's as if the scaler can handle the resolution that is coming in. If you get anywhere with this then please update this post just so we know that it works etc.
TIA
Syphon
Every other resolution over VGA works fine, just 1080p is rooted. I'll try VGA from my video card, to see if it is indeed the XBOX 360 at fault or not. However 1080p from component is scaled fine.
Pictures can't really do it justice (especially my attempts). You have to see one in person to truely appreciate how good it looks.
As I said in another post, what are the chances that an WFP-HC version of this monitor will land within a couple of months of the WFP original coming out?
