themark said:Try one of these: http://images.amazon.com/images/P/B000051WSG.01.LZZZZZZZ.jpg
Easy to re-position, and no cramps! Works for all kinds of Dremel/file/saw work
i like the way you did the logo on the handle.. i was thinking it would look slick with a piece of EL sheet behind it... what ever color you where planing on makeing the rest of the case... feed the wires up from under the logo, and use that flat plastic ribbon stuff like they use inside of keyboards, (its like a circuit board on celephane...im not shure what they call it ill see if i can find a link) just route the ribbon tight against the handel so you cant see it and hide the power converter somewhere out of sightFanatik said:
Fanatik said:Cool idea but I've never like the look of el sheet. That blue green or blue isn't in my color scheme. Unless they come in white or better yet there is a way to do the same with white leds. I'm mainly using white leds through the case.
I agree with him, an EL sheet behind that, with maybe a thin layer of roughed up plexi over it, to disperse the light nicely would look great behind that logo.thore said:i like the way you did the logo on the handle.. i was thinking it would look slick with a piece of EL sheet behind it... what ever color you where planing on makeing the rest of the case... feed the wires up from under the logo, and use that flat plastic ribbon stuff like they use inside of keyboards, (its like a circuit board on celephane...im not shure what they call it ill see if i can find a link) just route the ribbon tight against the handel so you cant see it and hide the power converter somewhere out of sight
thore
Fanatik said:Well here it is. Our logo on the psu windows. First we can`t mod without some good music. The Subways are awesome.
Here is the psu finnally mounted.
Yes, as long as this aluminium cover is groundedFanatik said:Elledan, someone mentioned this too but Zapwizard told me I shouldnt have an issue with emi. If there is EMI coming of the ballast will having the aluminum covering the ballast help?
KEEP UP THE GOOD WORK!!!!!!!!lesman said:My god, this just keeps getting better and better! NEVER STOP!
