I use a razor, I'll give it another go today though.BioVader said:I use a credit card to apply it very very thin... Same thing with the GPU... Also you might as well set your LTD to 3x or 4x...
Roliath said:I use a razor, I'll give it another go today though.
Thanks! Supposedly they had 4 left in stock when I called, and the guy assured me that I would be getting one of them.Budwise said:i got a 170 this week from a place www.digitalhotbuy.com
Give em a try. They had good prices and shipped very fast.
EDIT: I just checked them, and they are not OOS too! lol, wow, just wow... Im glad i got mine when i did!
I just did a pricegrabber search, and every single place was out of stock...
two cores @2.5 > then one core at 2.7Roliath said:Well I have an Opteron 170 CCBWE 0541RPMW. And it's overclocking is nothing to write home to.
Initial testing shows that 2.5GHz is dual-prime stable with only 1.4volts.
2.6Ghz is not dual prime stable with 1.4v, but is stable in all of my games, benches, spi, and others. this chip is certainly voltage hungry.
I have made up my mind and am selling this chip on Ebay. I'll try my luck with a 175 (could use an 11x multi).
I mean 2.5GHz isn't bad, but coming from a 2.7Ghz Sandy I wanted to get where I was or higher, not lower.
Well my new Opty 175 is two cores @ 2.7Ghz over my old Opty 170 @ 2.5GhzSKy042 said:two cores @2.5 > then one core at 2.7
I'll admit, I thought that very same thing. The only differences are that the 170 offers a higher multiplier, which helps those who can't reach a very high HTT (someone correct me if I'm wrong), and is clocked 200MHz higher than its 165 counterpart (1.8GHz vs 2GHz). So, for some the 170 is a better solution depending on their given system hardware.Swishbish33 said:This is probably hard to quantify, and not a popular statement, but I'm not sure that the extra $100 for the 170 over the 165 can't be better spent elsewhere. Seems that OCs are 200mhz more on the 170. Am I crazy?
RegisteredToPost said:For the five minutes i had my opteron setup running, the cpu temp was 29c at boot, idle. I was rather impressed with my choice in cpu coolers. Dual 80mm exhaust fans, and a 120mm thunderblade blowing on a scythe ninja. Two additional fans in the front of my case. One is an adjustable enermax, and the exhasts are zalman, silent fans. You can barely tell the system is runnning
It's for reference dude. I doubt many people are having problems idling... It doesn't matter anyhow - as everyone's interpretation of "under load" is going to be different, in addition to the ambient air temp of the location they are in.drizzt81 said:I do not want to flame, but I wonder why people even post 'idle' temperatures. None of my CPUs are ever idle, either I am using them for some purpose, or they are running F@H. I really don't think that people should care about idle temperatures, since I could care less if my CPU fails when idle. If I cannot put load on a CPU, it is worth nothing.
dang wish my 0530 would do that... 2.7 won't even run prime at 1.42v, looks like its passing at 1.47 though...Demenion said:Opteron 170 0530
Prime stable at 2.8 GHz @ 1.42V
It does 2.7 at stock volts (1.33 in Windows)
I will give that a shot this evening.kirbyrj said:I can get up to 2.65Ghz or so with 1.4V on mine FWIW.
Gun_Strife said:undervolt i believe
mine doesn't overvolt at all, it undervolts.HybridHB said:http://www.xtremesystems.org/forums/showthread.php?t=80477&highlight=dfi+overvolt
Im not sure how conclusive that is but the information shows that it does overvolt by a little.
Phadeout said:I have an 0536XPMW, can do 2.6 but only at 1.55V.
Got it Nov 8, from PCCanada (actually Insight.ca but same warehouse).
It's nothing special. May try my luck with a 170. I don't need the 11x multi anyways.
Hey guys, you should post where and when you got your processors too.
its alright, with the change in climate from moving from western washington to the dallas area, i lost 100mhz, but now i can clock at 2.7 at a much lower vcore, i was having to run at 1.65v for 2.8, and now, 1.47, so much cooler, dropped about 10C at load.Budwise said:update on my 170 CCBWE 0543TPMW:
With the new watercooling, i have dropped from 2700 @ 1.48-1.50 to 1.45 or lower (still testing). I tried to get 2800, but even on high end water its just not workin. At 1.6Vcore 2800 was stable in Prime for about 10 minutes and then the same old lame core fails. To go from 2700 @ 1.45 to 2800 at 1.6+ just doesnt seem worth it at all to me. I had a little higher hopes for this chip on water, but it just fell short on me...
Budwise said:sounds like the 0530 and 0543 are almost identical... Both struggle to hit 2800 but hit 2700 very easy...
