I've been meaning to comment. But trolling is always fun. lol. The LCD display thing is pretty cool, but I'd miss my front USB ports too much. Overall lookin pretty good. Just a note your heatsink fan and psu will be working againist each other. Have you looked into the NT06 thread?codeflux said:ok, let's have a few more comments like that, and i'll post another round of pictures.
i have a tiny 4-port USB hub on my desk, next to the monitor. if i ever need to plug anything else, i use it. but so far (over a month passed) i haven't had a need. front USB ports, albeit useful sometimes, are usually overrated.VoBoy said:I've been meaning to comment. But trolling is always fun. lol. The LCD display thing is pretty cool, but I'd miss my front USB ports too much. Overall lookin pretty good. Just a note your heatsink fan and psu will be working againist each other. Have you looked into the NT06 thread?
BurntToast said:Why didnt you get the 1900XTX or at least a 7900GTX?
Also why did you decide not to use the Accelero cooler?
codeflux said:i used FedEx. i doubt it was the shipper's fault - i think the green padding was damaged by AMD in packing or manufacture process.
i did find out the hard way that NEWEGG no longer gives RMAs in some products they sell - including all the parts i needed to return: Asus mobo, X-Fi card, SATA DVD writer - and, well, i would also return the CPU for replacement. on their RMA page they listed "this item is warrantied through the manufacturer and newegg does not give you RMA and go away" or something along those lines.
Ah.. the link, didnt try that till just now.Viper87227 said:Look at the link to his first thread. The date is 03-04. I dont believe the 7900 series was even out then, but I don't recall. I wondered the same at first also, why get a 7800GTX over a 7900GT, but tha'd be the reason.
Far as the accelero goes, its my opinion that that thing is crap. May be his also
with the stock cooler the hot air that was coming off of the video card was blown back into the case. this caused the ambient temperature to rise, which increased the GPU/CPU temperatures - vicious cycle. with the new cooler, the hot air is exhausted out of the case. this makes the air that's used to cool the videocard - and the CPU - cooler. also, it improves case airflow - approximately about 20cfm, judging by the volume of the air being exhausted by the GPU cooler.VoBoy said:Wow interesting, if changing to an aftermarket GPU cooling can improve case and cpu temps, I'm in!
codeflux said:does anyone know WHY, exactly, Arctic Cooling NV 5 Rev 3 doesn't fit the 7900GTX? does it bump against some capacitor or something stupid like that? - or is it more serious, like holes not lining up or chips in a different place or something?...
Dremel is my friend. if they tell me that it's just bumping a capacitor or something I'm going to cut it off. NO NOT THE CAPACITOR! the place in the cooler that makes it not fit. just grind the f.cker out until it fits.Viper87227 said:I woudl guess its caps in the way. The mounting holes are the same, so thats all I can think of. They do have a different PCB layout. Most aftermarket coolers do work on it, smaller ones. But, full card waterblocks don't fit it either. It's got to be something in a different spot on the PCB that makes the large coolers not fit right.
BurntToast said:Also why did you decide not to use the Accelero cooler?
that's true, but that's not why i didn't go with Accelero. its design is such that the hot air is blown directly onto the motherboard. this would be a very bad thing in a small case with very moderate airflow.chameleoneel said:the fan on the accelero sticks out like 1 or 2 inches over the side (top) of the card, this is NOT compatible with MOST SFF situations.
It fits on a 7900GT after a little bit of moddingcodeflux said:does anyone know WHY, exactly, Arctic Cooling NV 5 Rev 3 doesn't fit the 7900GTX? does it bump against some capacitor or something stupid like that? - or is it more serious, like holes not lining up or chips in a different place or something?...
rofl! that's an old mod, custom. 5mm acrylic, blue leds, USB-powered.NapalmDeath said:the point is that his mousepad glows blue !
