elvn
- May 5, 2006
I'm interested in whether the 7900GTX and 7950GX2's fit in the SG01 also. thnx
Um, I am using 3 out of 4 SATA ports. I have the PlexWriter SATA drive in there along with a 74Gb Raptor and a 400Gb YR SATA drive.codeflux said:E, thank you for posting the pic! looks like half an inch at most, not 2 inches. and yes, getting the SATA connectors in may be a problem, especially in my case - i need 3 out of 4!... and if i used SATA DVD drive, i'd need all 4!...
p.s. mmmmmmmmmmmmmm GX2 quad-SLI..............
codeflux said:did you guys read the latest 7950 GX2 SLI review on hardocp.com? Need For Speed Most Wanted shows no performance incrase with quad-SLI. So, no quad-SLI for me.
my point exactly! just like there is no point using a 64-bit OS and running 32-bit apps on it.Outrigger said:you will not see any increase in performance UNTIL apps and games are actually written to TAKE ADVANTAGE of it. In other words, you can dump countless gpus and video rams into a single machine and it won't do squat for games out today.
codeflux said:strangeness!
i i posted earlier, my CPU fan has been running at 100% (2700rpm) with the eVGA motherboard - haven't had a chance to install zalman fan controller yet.
my temperatures have been 44C idle, 50-52C load (depending on room temperature). before, with Foxconn it was 40C idle, 50C load.
strange, but who cares.
so, last night i reboot the box after uninstalling some monitoring software (HMonitor and SpeedFan), and my temperatures are now 34C idle 40C+ (haven't had a chance to torture it yet) load. btw, i'm using MBM5 with custom nForce4 config file to read the temps.
woohoo.
i used VK202-24-USB - some modifications required.pijje1 said:codeflux could you tell me the model of the matrix orbital vfd you used as here in the uk there are many as i would like to do the same sort of thing with my sg-01e. Also i to am thinking of getting the evga board as i was looking at the MSI K8NGM2-FID but am not sure if it is any good as their is not info about it. If i was to use the evga i was going to only use two INN 3D 7600gst clooked to gpu 600mhz and 760 (1.52ghz)
codeflux said:there was a little thing with my FX60 CPU you guys might have missed.
when i got the CPU box... it looks all intact, but rattles a bit... i open it to find that the heatsink came loose, and SMASHED everything inside. think "bull in a china store" situation here.
the CPU is out of its little plastic box, sitting loose. some of the pins are bent. the heatsink fan has pieces of green padding stuck in it. it is a complete mess.
i straightened up the pins, and tried fitting the CPU into the socket - it fits fine. further testing showed that it indeed works just fine, although getting the CPU cooler cleaned from all this green stuff would be time-consuming - good thing i am not using the stock cooler.
the CPU has been working trouble-free for over a month now. but memory of seeing it covered in green dust that used to be protecting it still giving me nervous giggles.
I will humor you... no, not even close. Look at some benchmarks.codeflux said:too bad 8800GTX won't fit in this case.
now, the $500 question is - will a single 8800GTS be faster than my 7800GTX SLI?... things to consider - i only game in 1920x1200, with maxed out quality settings.
i have been trying to find benchmarks. it's very difficult to find something that can let me compare apples to apples... details would be appreciated, and spare me the sarcasm.sleepeeg3 said:I will humor you... no, not even close. Look at some benchmarks.
HOLY CRAP this is the one most useful application i found to answer all my questions about video card performance! thank you very much for posting this!!!quique55 said:A gem of a tool as I found! Was looking for benchies myself and this is a good start. Wish they updated it with newer games.
i'm independently wealthy. well, ok, i'm not, but one day i may be. meanwhile - i have a job. Programming jobs pay fairly well in California.Miami_Fly_Guy said:what the heck do you do where you can afford all this stuff?
(im a broke student lol)
yeah, imagine my fvcking surprise...synaps3 said:Wow, I never thought I would see this system hit a bottleneck
