ColinR said:Maybe it's just because it's a different colour (or texture, and the camera makes it look a different colour). You could respray, but there's a chance that you'll have to respray the whole thing, because the whole of that side will look odd.
Or maybe it's because of the curved corners at the top, but right-angles at the sides. Not a lot can be done about that without redoing it. I'd spray it, and see if that helps enough (as that will require less hassle and downtime).
rogue_jedi said:so, if you short something putting it back together, we'll never know what happened? you'd better be careful...
hehe looks really nice.
Ah. Looking very closely at the pic you can see this, but it wasn't immediately obvious. That is some fiiiine detail, man. Very nice. But I can see this being an issue. You could file it down by the thickness of the aluminium, but that's walking a very fine line between "looking great" and "scratching the visible part of the window". Just spray it and hope for the best.Votey said:Thanks for the input.
...snip... "bevel" ...snip...
Soymilk said:is the piece of window that you cut out symmetrical?
this is an awesome mod btw, totally kickass cuz of the lack of enthusiast matx boards. the only quirk i'd have w/ it is that it might look strange after everything's put together and running cuz of all the output cables being on a side instead of the back. but then, it'd b unique, too. keep up the good work
Soymilk said:ah, that makes sense.
im having conflicting hopes now: this is a cool mod, so i hope that a enthusiast board thats pretty much as good as a full atx board doesnt come out, cuz then ur mod is kinda pointless. well, u could make it into SLI but then i'd b too lazy to do a mod like this, so i want a good matx board to come out.
Soymilk said:...if only it took less effort to do
Soymilk said:oc that sucker and post temps
same to you, pal!Votey said:
brasherman said:Double thumbs up to a great first mod by a fellow michigander and a post from another kzoo [H] member.
Looks great, and I had a thought on your window bevels. When I do body work, a lot of the time you use pieces of the leftover panels to fill elsewhere if you need it (like mirror holes and such). What you may have been able to do was find someone to help you and cut the old lower portion in half vertically and keep the bevels. Does that make sense? You could always use the old lower part to remake the new lower part. But all in all a very nice job in the cuts and thought you put into this. One thing though: This is the reason I build a new machine and move my old stuff to the lady's machine. Then when mine's down, I am not getting yelled at!
ah, that's why they look familiar. i was using the mdr-v900s for awhile. sennheiser 280s pwn them the 900s are very similar (looking) to those, just silver.Votey said:The headphones are MDR-V600. I've had them for years.
Votey said:I feel like I have to warn you all that the X-QPack is kind of a piece of crap as a case. The HDD LED does not work (check the SFF forum for others with this problem), the front audio ports don't work (at least with my MB), the front USB ports don't work (again, could be just my MB, but I doubt it).
rainman said:Votey,
You inspired me. I've been looking for a nice small case for my new computer (which until now was sitting on the DFI box running in the open). So I got an X-QPack silver with no window. I have now stuffed my computer in and just need to make that dreaded cut in the case lid.
How did you make such a nice cut?
PC-HAngover said:Well, my front USB ports work just fine, as well as my HDD light. However, my power on light does not work, because the connector is a 3 prong, and my P.O.S. ECS RS480-M is designed for a 2 pin, argh.
BTW. Awesome mod! I was thinking of doing something similar because I can't stand the shitty ECS RS480-M any longer. But then I realized that the new T-Force mobos are coming out soon, so I will stick to mATX, for now.
Votey said:Thanks!
The USB ports on my Antec case worked just fine with this same MB, so I know the problem is with the QPack. I'm thinking of swapping them out, and putting the Antec's ports into the Aspire. As for the front audio, I don't know what's going on. My front audio pins on my MB had two jumpers on them, which I had to remove to plug in the cable, of course. But when I did, the L/R front channels in my 5.1 setup went dead, and the front headphone jack was also silent. I tried NVSwap, but that was no help. Only when I removed the cable and plugged the jumpers back in did the sound come back.
I just had a thought: As I said, I didn't bother plugging in the front temp display thing. Maybe if you don't plug in the temperature display's power connector, the front ports don't work...?
