That_Sound_Guy
- Apr 29, 2002
rogue_jedi said:same to you, pal!
Dude, thanks for the laugh. i was almost in tears...
evaseeker said:Votey
i one word for ya(well many)..
you are amazing,, i think i did not see anything quite like that in terms of extreme modding....
i mean its not that extreme but the idea was extreme in the first place,, so again you did an amazing jop..
evaseeker said:i think i need to get my #%% up and try something like that..
Soymilk said:is there enough space to keep an entire matx mobo inside and have right-angle connectors sticking off all the parts and leading to the back?
Soymilk said:am i correct about the reason y the mobo isnt facing the other side is because then the video card would hit the psu, and u cant cut that?
Soymilk said:hmm... but then if you're not the type of person that needs a lot of hard drives (read: you use only one, or maybe two depending on how far over the video card goes into the hard drive cage thing), then you could put ur hard drive into the floppy slot, and proceed to cut up the hard drive holder as needed.
revenant said:That's a bad-ass mod! nice work!
Votey said:I have two 160GB HDs that I want to setup as a RAID 0 array, but thanks to my "l33t m0dd!n skilz" I have no room in my case to put them.
Soymilk said:...ghetto mod it w/ zip ties or duct tape or something like that, and have it strapped to a side or duct taped to the top of the shell where there might be enough space i mean, there HAS to b space in there SOMEWHERE that a hard drive could fit in, and thus be strapped in.
[LYL]Homer said:Can you move the curent HD toward the front of the case and have the second on edge mirroring (no pun intended) the first so the cables are butting up against each other in the middle. Of course right angle power connectors (or SATA drives with right angle connectors) might make that easier. In the pic above to the left of the WD800 is a grille of holes, could those even be taken out so the HD sticks out into the plastic of the front cover?
GREAT JOB on this mod!
Soymilk said:...wow. just wow. took me a minute to realize what "re%" was supposed to mean. couldn't you have just typed "represent" next time?
and i think i missed something here. so how are u getting 2 hd's in now, is it by ghetto modding it, or the suggestion that the other guy made w/ 2 hd's sharing one cage slot thing, or does using the top pci-e slot in a sli board not take up the floppy drive space or what?
and wtf how do u get cereal bits inside ur comp?!?!?!?!
Heh, I totally agree. If you want to be lazy, you can take a pair of pliers and bend those pins off the sink. Done it before.Votey said:40mm fans do not belong in computers that are used by people who can hear.
Votey said:Okay, here's the issue. I love using this heatsink for my "northbridge"...
It's quiet (duh), reliable (re-duh), and it works just as well as the stock fan.
But if I want performance from my video card, I want to use the upper x16 PCIe slot. Besides, using that slot allows me to have two HDD's in my case. So I want to cut some of the pins off the heatsink so it can fit under the card here...
in place of that crappy fan.
PC-HAngover said:Well, my front USB ports work just fine, as well as my HDD light. However, my power on light does not work, because the connector is a 3 prong, and my P.O.S. ECS RS480-M is designed for a 2 pin, argh.
BTW. Awesome mod! I was thinking of doing something similar because I can't stand the shitty ECS RS480-M any longer. But then I realized that the new T-Force mobos are coming out soon, so I will stick to mATX, for now.
He should be able to, I had to do that with the same NB cooler in my Micro Fly for the caps on my vid card not to hit...hehahohee said:Can you bend the pins?
