if you could, please look. if you need me to supply you some images that i see banding with, please let me know. now i really want to know if it is just my monitor or if all of them will do it.I bought one this weekend as well, but do not have any banding issues that I can see. I have been pretty picky about it to be honest. The Dell 22" I had for a few minutes was horrible about banding. I can look more tonight, but I have not seen any banding yet.
on a side note, i found one background image, that when i set it, the entire image seems to "jump" around. very weird. the pixels in part of the image will just jump around and act all funny. i can find it and let you try it too.
here is what i did for 2142... Edit the Battlefield 2142 shortcut, and set the resolution to desired specs. Also, be sure to change "+fullscreen" to "+widescreen" For example, the command line would look like this:I am running 2142 @ 1400X1050 and get black bars on both sides. No stretching. For some reason, in 2142 it also gives me the option of running @ 1600X1200. This option does not show on the other LCD, just the 226BW. I have not had the courage to try it, but it is indeed strange that the game thinks it can run @ that on this monitor.
"C:\Program Files\EA Games\Battlefield 2142\BF2142.exe" +widescreen 1 +szx 1680 +szy 1050
i have an ATI x1800XT and it seemed to run fine in that resolution. i am sure your x1900XTX could also handle it. but then again, it depends on what kind of frame rate hit your are willing to take. i usually get around 40-50. sometimes more and sometimes less. it sure does look purty though
