Peach said:the motherboard is also upside down.
If the skin is as thick as they say (4-8mm), you won't want to be cutting it too much.nytrackstar said:what about a double rad on top?
larkin said:and some more bling
sprocket said:If the skin is as thick as they say (4-8mm), you won't want to be cutting it too much.
The video card is hot on the gpu side, that's why the heat sink and fan for the vid card are on that sidefallguy said:and the air will be pretty warm from the video card.
They are 92mm and are intake NOT exhaust. You still recommend potining a cpu fan at the intake fans? i dont think that is keeping with the overall air flow design, pointing it up, twords the exhaust is. Either way you cut it there is a hot video card right under the cpu heatsink, nothing you can do about that bud. Hot air rises, the fan will expidite the circulation of hot air out of the case. Any other direction of the cpu fan would be plane stupid (vertical alighnments would inhibit the heatpipe technology and blowing air downwards in opposition to the exhaust is also dumb). Where do you want to point it? lolfallguy said:Why not mount it so that the air flows with the overall case design? Such as, having it blow out of the back of the case, in the direction the 2x80mm's are?
altec said:I don't like it. Looks like a V1000B copy, but half assed.
larkin said:The video card is hot on the gpu side, that's why the heat sink and fan for the vid card are on that side
I would take this instead, hands down.altec said:I don't like it. Looks like a V1000B copy, but half assed.
_Korruption_ said:I would take this instead, hands down.
- Unibody design (UNF 8mm aluminum)
- Motherboard doesn't mount upside-down (the A8N-SLI Premium doesn't like the upside-down Lian-Li cases)
- Lots of slow, large-diameter fans equals low-noise when undervolted
Plus, the workmanship looks even better.
larkin said:A few of you have asked for a measurement of the PSU/HD Cage space. I was about to do that a while ago but I found out i dont have a ruler/tape measure, so that'll have to wait at least until I ask my next door neighbors for one.
Crazy Chuckster said:ROFLMAO, you have a 400 dollar case in front of you but no tape measure or ruler. I dont know about anyone else but thats funny
Use your local coins/currency and tell us how many coins across. We can find the length of the coin onlineCrazy Chuckster said:ROFLMAO, you have a 400 dollar case in front of you but no tape measure or ruler. I dont know about anyone else but thats funny
so is the v1000 is the g5...RoyalAssassin said:Interesting, and wasn't everyone saying the same thing about the V1000b ripping off a G5? Thought so. This case is flawless.
larkin said:I'm a little under the influence right now... but i happen to have some pics of that very thing from earlier in the day... and don't worry. i dont do non sobr installs.
happy viewing
[pic1 - psu being intalled]
[pic2 - psu with removed hd cages]
[pic3 - mobo tray with some goods on it]
and some more bling
The two cards fit fine. Mine are single slot cards so there is actually two PCI slots still open when both cards are installed. One slot is between the two cards, the other slot is at the bottom, right bellow the 2nd card. ASUS provides a flexible SLI link cable so that putting a PCI card between the two won't block the link. The airflow is a bit constricted, I dont know if it's any worse that then premium however, my a8n32 came with the latest 1009 bios installed and is revision 1.01 and I've had no issues with ACPI or anything so I definetly stick by the A8N32 over Premium decission. From an airflow/temp standpoint I think the lower placement of the PSU might be adding the most to the temps. The PSU is hot and since it's on the bottom the hot air rises through all the hardware before it finally leaves the case at the top.TonyM16 said:how will it all fit in a Asus A8N32 SLI. I can't seem to decide between a A8N SLI Premium and the Asus A8N32 for exactly this reason. As theres doesn't seem to be much airflow , if you use two graphic card and a sound card. What is your take on all this? Do you still stand by your decison odf a A8N32 instead of a A8N Premium.? Also what kind of temps are you getting ? For the mobo cipset, your graphic cards and your cpu?
Yep, would stick with all of that. It's awsome.TonyM16 said:2) After using all your kit would you still recommend I but the TJO7 and a Asus A8N 32 Deluxe, instead of say something else? Also I have got the Corsair 3500LL Pro ram, which is supposed to work best with the A8N32.
I wouldn't change the top fans to intake, that sounds like a bad idea. But I would like to experiement with temps if the rear fans are changed to exhaust instead of intake. I know the question then is where does the fresh air come from... The stock fans are very quiet tho, at least by my standards, the 120mm are great, the 92mm fans though are definetly the dominant "tone" sound makers, replace those with something quiet and you'll be good.TonyM16 said:3.) How is the cooling on the TJO7? Does the air short circuit at the top, or does it reach the VGA area aswell? Also have you considered changing the fan congig, to two 120mm top intake and two 92mm rear exhaust? I will proabably be replacing the 120mm fans with Akasa ulktra quiets (cause they can be connected to a fan controller), do yu think thatrs actually needed, or is the stock cooling quiet?
TonyM16 said:Thanks for reading and cograts on your rig. It's brilliant, and exactly what I am after at the moment.
