d50man
- Jan 22, 2002
you are gonna dump that heat indoors....... good luck
Take a look at your local junkyards, I haven't seen any (granted, I haven't been looking) Priuses in them yet, but they're bound to start flooding the junkyards within a year or so given the volume they've sold. You'd need a decent amount of mechanical skill to identify a 2004/newer prius and remove the ac unit without damaging it. On the other hand, a sledge hammer and a really big electric saw could get the job done too. One thing you're going to have to be aware of, cooling well below room temperature creates a dangerous environment inside the case. Condensation will form on your tubing (especially if the fluid is below 0C/32F) and eventually build up and drip on your components. Fixing that should be as simple as putting some insulation around the first couple segments after the AC until the fluid is around ~20C/70F.
Good to know some of the computer techs are familiar with real machines (wait a minute...did I just call a Prius a 'real' machine? HAH). Good luck finding a wrecked Prius, if I crash mine soon I'll send the part your direction.
I don't think you are barking up the right tree here. a automotive AC system uses R134a refrigerant. Basically each "water block" in the CPUs, and chips sets would have to have an evaporator. All air conditioning and refrigeration relys on "phase change" been it some type of freon (R12, R134a) or even ammonia in large commercial freezers. The cooling effect when the liquid is expanded into a gas is how the whole thing works. This method isn't new for cooling CPUs. There once was a company that manufactured a PC that had a built in compressor, evaporators and condenser to cool the CPU for over clocking. This was back in the Celeron-A 300Mhz days. Those chips could be pushed to near 1Ghz with enough cooling. That was astounding in those days.
What did you think of my suggestion in post #44?
I asked for feedback about using an A/C from a different model of car which used the standard belt/pulley driven system. How difficult do you think it would be to change the belt/pulley system for a motor instead?
Shingoshi
If I understand you correctly, the basic premise is as follows.:
1.) In order for heat to be removed from the system, the coolant must be at a higher temperature than the ambient temperature. (I get that)
2.) Using an A/C system to lower the temperatures of the liquid-coolant, would lower those temperatures significantly below ambient. The result is no heat would be removed from the liquid-coolant if it were transfered out to a radiator.
3.) The only way to dump the internal heat of the system is to have the A/C condenser outside of the case, NOT a radiator.
So here's the change in plans:
1.) There will be no external radiator.
2.) There will be no submerged condenser.
3.) The A/C condenser will be mounted outside of the case.
This change will result in the proper removal of heat from the system. So now I need to find and purchase my large condenser.
Shingoshi
I had thought this was your plan from the beginning. I must've skipped over the part where a radiator was mentioned. I'd say continue on this thread, there's already a lot of information in it, it'd be a shame to let it die.
If you have a refrigeration unit with enough capacity to dissipate all of your heat then your condenser should be your only heat dump for the whole system. This is what must happen in order to achieve anything very far under ambient. You might refer to this thread in Extreme cooling section for some ideas.
http://www.hardforum.com/showthread.php?t=1424727
The only difference is that you are trying to cool to lower temps so your fluid will be something different that won't freeze.
For sub-zero you are going to want to avoid derlin, acetal, plexi, etc. You'll want an all metal block like the all copper Heatkiller. If you are going "deep sub-zero" you will need to figure out your fluid.....then that may cause you to need your all metal block brazed shut.
Every damn time I buy something, I cringe. I just brought my liquid-coolant housings. They are a pair of Flowmatic Full Flow 20" housings with 1" female NPT threads. You can see them here:
https://www.freshwatersystems.com/p-2243-20-full-flow-clear-housing-1-press-relief.aspx
See this link for an idea of what I'm talking about:
http://www.hardforum.com/showthread.php?t=1421690&goto=newpost
Since any liquid will boil if subjected to a high vacuum, I'm thinking of doing that in my application, in combination with the techniques for better efficiency.
Shingoshi
# Operating Pressure: 30-100 PSI
# Operating Temperature: 40-100°F
How do you plan on providing the minimum 30psi required for operation?
1.) Sub-zero is well below the rated low end temp of the item. How you gunna fix that?
2.) So, now you are going to incorporate miniature bongs and pull a vacuum?
StarKiller, Lexan has a low temp rating of -60 and shouldn't have any problem with the temps in the cooling chamber. The view window for the cooling chamber will also have 1/2' Lexan.
Freezium is a potassium formate based secondary coolant for indirect cooling systems.
Indirect cooling systems are being more and more applied due to the environmental discussions concerning the use of halocarbons as direct refrigerants.
Indirect cooling systems make use of a transport medium to bring the cold to where it is needed. This transport medium is usually called secondary refrigerant or secondary coolant.
The ideal secondary refrigerant should possess a good thermal conductivity, high specific heat and low viscosity. It is also important that the secondary coolant is non-toxic, non-flammable and compatible with common engineering materials.
Freezium is a secondary coolant offering all these benefits to help you transport cold in an economical and environmentally friendly way.
Freezium has been commercially available for a number of years and has been applied in many ice-rinks, food processing plants, chemical plants and cold storages. The most recent application has been in the refrigeration system on the Queen Mary II, the worlds largest cruise ship.
Answers:
1.) Your concerns are valid. And I may be headed for disappointment here. However, I'm hoping that the advertised constraints are listed for sake of liability protection, and not determined by real physical limitations. But that may be the case. At which point I will have to make some modifications to my design. I may have been wrong (misread), but I thought the minimum temperature was -40F. I don't see how they could practically limit the usability of these units to just above the freezing point. Think about it for a moment. Would you want one of these things bursting inside your house if the electricity went out int the middle of winter. Maybe then you can see my point about liability.
Given the wall thickness of these units (rather substantial indeed), I don't see them becoming brittle at low temperatures. That also could be the case in which I'm screwed.
If all of this are the real limitations that I'm facing, then I'll have to be content with sub-ambient temperatures, instead of sub-freezing. I'll have a better idea of what I can do when I get my reservoirs next week. I just found out UPS updated my delivery time to one day earlier. So hopefully I will have them on Wednesday.
Shingoshi
http://www.kemira.com/en/solutionsproducts/Pages/freezium.aspx
An indirect cooling system is precisely what I was intending to build here.
Shingoshi
This is the very sort of thing I was thinking of doing to the inside of my case.
http://www.expandingfoamkits.co.uk/
I'm only concerned about how much I want to apply inside the case. So of the components will need to be removed at some point for reason that may not be anticipated. Hopefully, design failure won't be one of them.
Shingoshi
Even though this thread specifically mentions the Toyota Prius as the candidate for the A/C compressor to be used, I thought about doing the same thing with any other brand last year. The basic task is to replace the A/C clutch with an electric motor. So I've spent much of this night looking for options to replace my intended target. I came up with this unit:
http://www.summitracing.com/parts/PLR-2118/?image=large
Summit Racing is the same place I brought the oil coolers I'm using for my radiators. You might want to consider them as an alternative source for components.
Anyway, here's the request. If I'm not the only one looking for a unit that can accomplish this task, all of us are likely to find out much sooner just how easy it may be to do this. I really don't think it's that big of an undertaking. The most important thing that I can think of, is having a mounting pattern that will accept an appropriate motor for the job. I only specified the Prius compressor because it was already matched to a motor, and didn't need to be modified. For modification, the mounting pattern should likely be square. Although, I guess an adapter plate could be made. I mean, that is what we do, right...
Another thing which some of you have already hinted at, is not having too large of a compressor that requires a motor so large (as in draining too much energy), that it would become impractical.
So if any of you are willing to participate here and report back what you find out, that would be nice and much appreciated.
serpretetsky, help me out here!
Shingoshi
I have an idea that I need to look into. It's a compact version of a bong, using a super low-pressure vacuum, instead of blowing air over a wick. I have to verify the practicality of this. I know that it can be done. I just don't know how much it will contribute to lowering the temperatures throughout the system.
Shingoshi
Is there a reason(s) why you are so focused on an MVAC cooling system?
