So thats a 6 bit TN panel using dithering to get 16.7m colors?travbomb said:Are you serious? Do some research next time.
http://www.samsung.com/Products/TFTLCD/Monitor/LTM220M1/LTM220M1.htm
PS - I work for an LCD manufacturer
How do we know for sure? My understanding it that this panel is a true 8-bit TN panel. Samsung usually lists it 6-bit panels as having 16.2 million.joemama said:So thats a 6 bit TN panel using dithering to get 16.7m colors?
If it were then it seems like Samsung would be sure to list that in the specs...not something to really downplay. I do know that all current 6 bit TN panels that list 16.7m instead of 16.2 are using dithering to sort of "fake it". All of these new 22" panels are being sold around the $400 mark which leads me to believe the extra 2 inches is the only improvement over 20" TN panels.trek554 said:How do we know for sure? My understanding it that this panel is a true 8-bit TN panel. Samsung usually lists it 6-bit panels as having 16.2 million.
LostStorm said:So if we are to believe that Vewsonic 22 will uses Chimei panel TN(which is most like true), heres a link for chimei 22 inch monitor. I wish a 22 inch monitor would come out with AS-ISP panel
Chimei
DefBringer said:The problem I have with these 22" is that you can't walk into a store anywhere and see one properly set up with a dual DVI Link cable.
I've only seen them at Best Buy at 800x600 with some fuzzy ass VGA connection. Impossible to determine just how bad this viewing angle problem is with that setup.
They use completely different panels. If you had bothered to read the thread you would know that the VX2235WM uses a TN panel. If you have a VX2025 then you might be disappointed in this monitor.christopher625 said:i just bought the vx2235wm today. gonna have to wait 20 days to collect it. hope it's as good as the vx2025, just bigger
trek554 said:They use completely different panels. If you had bothered to read the thread you would know that the VX2235WM uses a TN panel. If you have a VX2025 then you might be disappointed in this monitor.
Look closely at what I am replying to. I am saying that the panel in the VX2235WM is completely different than the VX2025WM therefore its not just a bigger VX2025WM. The guy I am replying too may not be happy since the panel looks like it is a lower quality panel.christopher625 said:But it's not yet confrimed. Some places say it's a Chi mei P-MVA panel.
Pretzel said:I saw the samsung 22" at Fry's. It's definantly a TN and doesn't look good at all. I'm assuming the Viewsonic will use a smilar panel so I went with the dell 2407 instead.
JohnleMVP said:I've seen the 22" Samsung for sale at fry's and its cheap $399. It also suffers the bad viewing angle problems as the Westinghouse 22 and Acer 22"
Last0ne said:Panel Film Type: I am 100% sure it is not a TN film TFT.
it's something else.. probably p-mva. There is no ghosting in game at all. Very good in term of response rate.
6 or 8 bit: on the box, it says 16.2M color.
Pretzel said:However, also like many, I am unhappy with the smaller size of the text and images in it's native 1680 x 1050.
Tutelary said:this made me laugh.
Scyles said:Then I'm 100% sure its not a P-MVA.
Dude, there is no way that a P-MVA only has 16.2M colors. My guess is that you just haven't had experience with a modern TN panel. The dithering has gotten much better recently.
Open up a text document, or anything with a white background, and then move your head to an extreme left or right viewing angle. If the white turns yellowish, its a TN.
xtasyindecay said:I missed that one - unhappy? Is that a serious comment?
brumwald said:So monitors do support dual-link DVI nowadays?
Not even 1920x1200 monitors supported dual-link DVI before and I don't see how any manufacturer would waste their money on something like that (especially now when graphic-cards actually do handle it...).
But I'd be glad if someone proved me wrong.
hiteak86 said:Here are some initial photos. Im still trying to find a good way to capture high FPS games without the blur.
http://i86.photobucket.com/albums/k112/hitek86/IMG_1295.jpg
http://i86.photobucket.com/albums/k112/hitek86/IMG_1289.jpg
http://i86.photobucket.com/albums/k112/hitek86/IMG_1288.jpg
http://i86.photobucket.com/albums/k112/hitek86/IMG_1284.jpg
The picture quality is great, with only minimal backlight bleeding on the top and bottom portions of the LCD. There may be one dead pixel that sometimes decides that it is "stuck". Othertimes, it works perfectly.
I will have a full review soon.
