LostStorm said:It is TN panel, I sent email to tftcentral cause they had it listed as mva panel, they did change it and now they have it listed as TN panel. Wasnt Dell suppose to come out with 22 panel (if they do I hope its ISP panel)
LostStorm said:Yeah i meant to say that i heard dell was coming out with 22 inch monitor and I hope it has isp panel. I will keep checking up on LG website thanks.
Hyperblau said:Dell is buying 100,000 of the 22" Chi Mei LCD panels a month for their 22" model. At the moment Chi Mei is the only manufacturer of any 22" LCD panels.
I recently bought a Chi Mei branded 22" screen and it is very good, colour is great, great viewing angles, no ghosting that i am able to see.
Not sure if this monitor is available in the US but i paid $580AUS for this monitor which is a very good price for the size.
DougWD said:Dear Doug:
Thanks for your inquiry. Since you are a photographer, I'd recommend
going with an VP2130b 8 bit panel over the VX2235wb (6 bit+2 bit FRC)
unit. This is the most accurate color you can get at this time; state of
the art.
Regards,
Tommy Jue
Sr. Quality Engineer
ViewSonic Corporation
DougWD said:What about this?
http://www.sonystyle.com/is-bin/INT..._20"&ProductSKU=SDMP234/B&TabName=specs&var2=
From research I've done using Tom's, TFT Central, and flatpanels.dk, that Sony seems like the best LCD panel out there for the price, which you can get for less than 700.00. Note it is true 16:9 (1920 x 1200) and 23", not 21 or 22 like the Eizo.
What do you think about that evaluation between graphic performance and cost?
DougWD said:Nope, they don't. It's got that LG.Phillips S-IPS panel in it.
Sony SDM-P234B (Widescreen) has a 23 inch 16 ms S-IPS (LG.Philips LM230W02) panel.
The only thing keeping me from snatching this 2004 technology up is that LG has announced its Enhanced Super IPS panels, with all the new enhancing electronics, which take the contrast past 1000 and blacks (which is very important in photo editing) to a VERY black level, and halves the response times all around. I just hate to fork over 700+ US only to get old technology and its drawbacks that new technology has now overcome--just a matter of them hitting the markets. Even so, I probably won't be able to afford it for 2 years anyway . But even if teh technology improves, the latest iteration of this LG.Phillips panel would be good enough for anything even gaming without blurring. I just wonder what the Sony P234B really perfroms like in real life. At Tom's they only posted a 412 contrast which is pretty shiitty compared to the ES-IPS.
So you think I should jump on one of those?
travbomb said:Everyone making 22 inch panels is making TN panels.
Samsung, LG-Phillips, Chei Mei, and Hanstar are all making 22 inch TN panels. Thats all there is too it. There are no other types of panels in this size.
travbomb said:Dell does not make panels so this would be impossible.
LG-Phillips almost exclusively manufacturers IPS panels and as of right now they are only making a TN 22 inch panel. I would check their site if you interested in if a 22 inch IPS wil be produced in the future.
DougWD said:Dude, wrong:
Result:
Philips 230WP7NS has a 23 inch 12 ms S-IPS (LG.Philips) panel.
psb said:But if I sit in front of it its a great gaming panel, and it cost me only $399 (some got it for $349) and it is therefore half the price of a 23" S-IPS
DougWD said:Stay tuned. From the reseach I did, the NEW IPS panels, called Enhanced Super IPS panels from LG. Phillips are due out anytime. This is suppose to be a big breakthrough in IPS technology.
I could not find much information on the panel used in the 225BW but there is really only one 22" 5ms model on the market today: the Chi Mei Optoelectronics S-MVA panel (P/N: M220Z1-L01). This is the same panel used in the ViewSonic VX2235WM and the Acer AL2216WBD. S-MVA technology was actually developed by Chi Mei Optoelectronics and offers 8-bit color depth, wide viewing angles and high contrast ratios. Although Samsung produces their own LCD panels, the CMO S-MVA panel was likely chosen due to it's unique performance characteristics and value.
if you are happy running that monitor at 1440x900 then I cant imagine what you would actually be unhappy with. sorry but lcd monitors look like total shit outside of their native resolution.Jack_Daw said:Hi, First post only discovered the forum 2 days ago while checking-out the ViewsonicVX2235wm.
With my limited experience i purchased this panel 2 days ago and it is very good and i only have it running at 1440/900/Analogue. Soon to be hooked up to my Mac G4.
There is the smallest,smallest amount of bleeding at the corners, the osd buttons are a bit fiddly(best use your thumbs)--No dead pixels and if any appear within fifteen days it:s covered. Great real-estate (I have to take a breather now when i empty the trash . The bigger fonts are a bonus for my 40yr old eyes, the black is deep and strong. This is my first LCD coming from a 19inch CRT and it has been worth the wait. This is imo a good looking monitor and suits my set-up (music software programming)
I think the metal sandwiched in between the frame helps dissipate the heat and keeps the whole panel tight, also another model is on the horizon it has an ipod dock on the front of the base. One happy customer here ;0)
