Cmdrmonkey
- Jul 19, 2004
It's crashing for me right when I enter the town of Megaton. I did remap the VATs key, so perhaps that's the issue. Hopefully Bethesda is quick with a patch.
Just a Heads up I was able to fix the problem by turning off the GX mode in the Xonar menu.. I hope that helps
Colin
Colin
I'm having this exact problem and have not yet determined a solution. I have been googling like mad in hopes that someone has already solved it, but I haven't found anything.Fallout 3 for me is crashing randomly every 10-30 minutes. It's not even crashing, but the screen is frozen while the music still plays. After that happens, I have to ctrl-shift-esc to force quit the Fallout 3 process.
It's really annoying :[
Let's compare rigs, see if there is something in common.
I'm running Vista x64, ATI 4870 512mb, Catalyst 8.10, X-Fi Titanium with 2.17.xxxx drivers, on a GA-EP45-DQ6 motherboard driven by a Q9450 @ 3.20 GHz.
Also, I had a weird installation dialog related the Visual C++ / dotNet 3.0 during installation. Oh, and I'm using the Steam version of the game.
I don't think it's the audio because I'm running it through a professional audio interface.
Oh, I also got that weird installation dialog as well about Visual C++/dotNet 3.0.
Since Gigas-VII is using an ATI card and pookguy88 and I are using Nvidia cards, it probably has to do with Vista x64 and it must be a separate problem from what other people have been encountering.
Glad to know that I'm not alone here
Are both of you F5ing as often as I am?
Audio for me comes from my E-MU 1616M.
That's a creative product, though. Professional or otherwise, it might be related. Also, professional audio equipment is notoriously bad at handling gaming, because it is designed for one thing really: recording. If my band and I recorded more often, or were turning a profit, I'd be running a similar solution, but for now my X-Fi does a good job there too.
That's not the point, though. Let's get back to figuring this out. Are we all running Vista x64?
I read something about Winamp and .OGG associations being a problem for the game on the Bethsoft boards. They suggested associating .OGG files with WMP. I don't know if this has anything to do with crashing, though, because the solution seemed to fix a bug where voices weren't being heard.
[H]ea\/y B;1033245133 said:I have had 1 crash since I started playing it, averaging about 5-6 hours a day. And the only reason it crashed was I alt tabbed out and it didn't like it.
I'm crashing right after I get the pip-boy. tried the exclusion thing.
the only crash i've had is if i listen to any radio station.. after a while when i go and Sleep i tcrashes..
i'm so glad they ahve lots of auto-saves in the game .. it saved me about 2 hours worth of playing..
so i basically just don't listen to the radio (too bad IMO)
^^ I wish my problem were that simple and isolated.
Alright guys, using vista x64 oblivion would always crash on startup for me, well what do you now, fallout does the same exact thing, I can't even play the damn game.
In the process of trying to fix my initial crashing problems, I have:
0) disabled ffdshow for 'fallout3.exe'
1) updated my motherboard bios.
2) enabled dotnet 3.0 optional elements.
3) disabled those same dotnet 3.0 optional elements again.
4) associated .ogg files with windows media player.
5) tinkered with 'FALLOUT.INI' for several hours, trying different combinations of settings.
6) Enabled Catalyst A. I. (I normally keep this disabled because it can make certain apps crash).
7) tried different settings in my X-Fi control center.
None of these things have helped. All the while, everything else on my rig works just fine.
I have noticed that my X-Fi does sometimes almost seem to crash on its own but never in games. It tends to happen while I'm using firefox, especially with youtube. Basically, until I reboot, or change the current audio mode, the card will SCP (static, crackle, pop). The SCP becomes especially bad during high-CPU utilization.
Fallout 3 is causing my audio to get stuck on a particular sound (probably the length of the buffer or something) and repeat it until I either reboot or try to change X-Fi mode. If I try a mode-change, the card will report that the device is in use and the mode can't be changed, but fallout3 will already be closed. From there, the sound will work again as normal, but the mode still cannot be changed until I reboot.
I've never had any other games cause these sorts of problems. What could be the problem?
Reverted video codecs back to default( I am on basic vista codecs right now)
Those with the music playing but video stopping crash might want to bookmark and check this thread:
http://www.bethsoft.com/bgsforums/index.php?showtopic=894046&st=0
E-MU and Creative drivers are done by separate groups and have very little in common.You are correct in that it is a Creative product but I have *never* had any problems playing games with it. Whether it's Crysis Wars or Far Cry 2 at the highest settings, this thing is just amazing for gaming..
Where Creative's drivers are often considered a POS, EMU drivers are one of the things E-MU's pride relies on.
There is just no comparison between the two.
