compwarez said:so the motherboard and the gts video card is the same size?
Eagle156 said:So how long is the 8800gtx? I measured my case and it had around 10.6" of room for the expansion cards.
SlikRig said:I was just messin with ya....its the same as mine..except its orange
SlikRig said:whats that huge 120mm fan in the middle of the case for?
Chromakey said:Can anyone tell me if the 8800GTX will fit in the Lian Li PC-101? I'd really like to get it as my new case.
If not, what cases int he Lian Li range does it fit in?
Thanks.
RobotChild said:I can't quite tell in the first picture.
Is that top G80 fitting? Or is it hitting whatever that black part.
No, no.kuyaglen said:I dont understand what your asking. The 8800GTX is 11 inches from the end of the bracket (where you usually screw it down to the case) to the end of the card. My superlanboy will have to be modded to fit it. One picture shows that the card would reach past the side load drive cage.
RobotChild said:I meant the first picture posted in the thread.
Which was the Antec 900
and you would know? (yeah it should be, im looking for a link )Astrogiblet said:G81's should be much smaller, by the looks of it.
Juic3 said:Can anyone out there help me with this case ?
Lian Li PC-7B Plus II.
From the looks of it, it could fit, SLI looks like trouble tho.
Its on weekend sale, and Ill probably be getting a G81 GTX when it comes out, want it to fit
jcll2002 said:and you would know? (yeah it should be, im looking for a link )
