NowhereMan
- Nov 22, 2003
I love mine. Games look great and no ghosting or other problems. Great monitor for the price.
why don't you just take the back of the case and put some 40mm fans blowing air out the top?i just brought one today and i've been running it since noon. i noticed as well that a lot of heat comes off this sucker and a faint burning plastic smell coming off the top if i stick my nose right next to the monitor. i'm not sure if it's because of some manufacturing coating but it probably isn't good.
since a lot of people complain about problems and that it might be connected to the heat issue (and i'm still in my 14 day return policy), i might mod my monitor for better heat dispersion. did anyone notice that the holes at the top on the back are pointed away from the screen horizontally? it seems like they should be pointing vertically if you're looking to disperse heat. i was thinking of taking my dremel and cut some vertical slits between the holes. i just have to figure out how to do it so soyo/office max will still take this under warrenty if it breaks for some reason
Hmm, mine puts out less heat than my 22" Westinghouse. It's an 07/2007.
i meant, take the back off and put the fans on the vents in the top of the back and put it back on, lol you could not even see thembecause that would look terrible and could easy fall apart/break/get me electrocuted
Can anyone who has gamed extensively on this monitor comment on the validity of the review.
"Gamers looking for a panel with a really good response time and very low smearing during fast-action games should look elsewhere. No LCD we have ever seen has totally eliminated the "smear" you get as objects move rapidly across the screen and pixels change color, but most of them do a better job of minimizing the effect than this one does. It's not as bad as LCDs commonly were a few years ago, but it's not up to the standards of today's newer monitors."
http://www.extremetech.com/article2/...2211599,00.asp
But when there is dark scenes and having my caracther going into caves and mines it doesn't look black were it was looking black in the CRT. On the LCD it is just like different shades of grey and very deep grey.
hello. I'm new to this forum and hardforum. Just bought this monitor yesterday and going through burnin now. This is my first LCD. Can you guys help with some stuff. I want to use the monitor to watch HD movies. Will I be able to. But first what I did was get a couple of things from amazon. My cuurent video card is a radieon 1100 VGA, ok I know, but I just bought a PNY 8500 with 512 on it that is suppose to do HD. I also bought a Pinnicle HD PCI card-waiting to be mailed from amazon. The Video card has VGA and DVI-my other did not have DVI only VGA so I'm currently getting an analog signal. Since this monitor is not HDCP I'm wondering if I'll be able to use the monitor to watch HD movies and pick up HD broadcasts from local stations...thank you
Thinking about purchasing this monitor on black friday or the Westinghouse 22" Widescreen LCD..
Both way under $250.
what makes people think this is VA based? Viewing angles suggest it is TN Film with those 170/160 quoted viewing angles.
would be interested if there is any supporting evidence for VA?
It's a BenQ panel, already been confirmed.
I have a TN panel right next to the Soyo and I can guarentee the viewing angles are drastically different.
I bought a Viewsonic when input lag and response time was a huge issue with LCD's, paid $880 for a 4:3 19" and it had severe ghosting, I returned it that same day and went back to my Sony 17" trinitron... used that until I found the VX922 (2ms response time) and then went to an FW900, then to the Soyo...
I see zero ghosting in my games, LCD tech has drastically improved.
i'm wondering this too.
and also, has anyone sucessfully played their 360 at 1080P?
Was anyone able to get the pdf manual for the Soyo off of Soyo's website? All I can get is a Not Found error.
Also how do you find out the manf. date? I still have the box and it's not on there.
Do you guys think OfficeMax will have a lot of these in stock for BF?
I really want this monitor because the deal is so good and the reviews mostly seem to say great things about this screen....however it would stink if I had mine break down on me.
How smart will I be if I'm still going to go after it?
