Santos L. Halper
- Dec 11, 2001
Volkum said:I'm hopefully getting a pair of 240s (1.4) soon. How do you guys think those will do OC wise (or would I have to provide steppings and such to get a decent estimate)?
That really depends on the Motherboard and RAM you get.
Those 240's will require Registred RAM and that doesn't usually come with too tight of timings or offer much for OCin'. Registred DIMMS are all about stability.
Also, many Dual Proc Boards don't offer a whole lot in the way of OCin' in the BIOS. They are made for workstation and server use. So stability is the key factor.
I have a Dual 246 machine at work that I built using a Tyan board. I've never tried OCin' it and from looking at the BIOS, I doubt I could very much. The RAM I use is OCZ ECC DDR400. The timings are 3-3-3-8.
You should be able to get some OC with the 240's, but I wouldn't bet on hitting anything like 2.8Ghz.
